1127 with PCI 4065 DMM problem
Dear All
We have a PCI 6065 DMM connected through Auxiliary cable to control a SCXI 1000 with 3 SCXI 1127 Switches
the point is that I was using the synchronous scanning example shipped with NI SWITCH , but what i found is that when i write ch0:18->com0; and choose the Number of samples in the DMM to be 19 , i figured out that the switch only stop at the very 1st channel in the scan list , and read it 19 times
what's wrong with this example and my hardware ? ,
Note: i successfully switch from channel to another using MAX
Regards to all
Eng. Mohammed Ashraf
Certified LabVIEW Associated Developer
InnoVision Systems Founder, RF Test Development Engineer
www.ivsystems-eg.com
(2,493 Views)
Hello Mohammed,
It sounds like your DMM is not receiving the scan advance trigger. What example are you using exactly?
Does the problem arise if a DMM/Switch Express VI is used? If so, then the chassis communicator may need to be reconfigured.
Can you read through this KB and determine if this is the issue?
Selecting Incorrect Communicating SCXI Slot Prevents DMM Switch Express VI from Working
Ryan F.
(2,463 Views)
