10kHz+ Square wave generation
In a piece of LabView-run test equipment, we need to be able to generate a
variable
frequency square wave from 1 kHz to 18 kHz on the AT-AO-10 board.
Currently, we use "Compute Waveform.vi" to generate the square wave from
a
panel control, using a 10 point buffer. We then use AO Config/Write/Start
with
"continuous generation" with a update rate of 10 times the frequency.
This vi works fine for up to 8 kHz. After 8 kHz, the machine slows down.
At
above 11 kHz, the machine will freeze up, and then at cause a reboot. Obviously,
this isn't acceptable.
Has anyone out there done a continuous square wave generator with panel
controlled frequency that can get to 18 kHz?
I'd appreciate any help in this matter.
Sincerely,
John
Patrick
Electrodynamics, Inc.
(3,007 Views)
We would prefer the solution to be a VI software solution only, not a
hardware addition, if possible.
John Patrick
(3,007 Views)
