1097 error with OpenComConfig !
Hello all,
I know that the 1097 error is a very common one, and it has been reviewed in this forum many times, but i couldn't find the solution to my problem .. Even KnowledgeBase didn't help.
I've written a simple code just to open a session with the serial port :
receive.c :
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include <rs232.h>
#include <utility.h>
#include <formatio.h>
#include <string.h>
#include "stdio.h"
#include "stdlib.h"
#include "receive.h"
int RS232Error;
int receive()
        RS232Error = OpenComConfig (1, "COM1", 9600, 0,
                                        8, 1, 4500, 4500);
        if (RS232Error == 0)
            SetXMode(1, 0);
            SetCTSMode(1, 0);
            SetComTime(1, 5);
        return RS232Error;
receive.h :
int receive();
I created the dll for that function, and the 1st time I run it , i get a 1097 error .. The 2nd time and on, i get a return of -7 (Cannot Open Port).
And if you're wondering why my portnumber is 1 and the device name is "COM1" although I'm using a PC, it's because when I use 0 as port number I get a return of -2 (Invalid Port Number).
Would anyone, Puh-leaaase, help ?
Message 1 of 10
(4,725 Views)
Did you try operating via hyper terminal?
Message 2 of 10
(4,723 Views)
No i haven't, coz it wouldn't be much of a help in my case.
Message 3 of 10
(4,717 Views)
More tests were done, and the thing is that everything is perfect when i generate a "Full Run-Time Engine" DLL and test it.
But when the DLL's Run-Time support is "Real-Time Only" , I'm getting these errors !
Medic !!! Please !!
Message 4 of 10
(4,706 Views)
Hi 0033.
Have you find any solution? Did you do more tests?
Regards.
Romain D.
National Instruments France
Message 5 of 10
(4,673 Views)
Hey R_Duval,
I'm out of tests .. Since that little code functions well on the PC, but doesn't function at all on a real-time machine !
I contacted National Instruments for that, and still no answer from their side !
Message 6 of 10
(4,664 Views)
HI
Do you have any feedback from NI?
Could you share the information?
Thanks.
Romain D.
Message 7 of 10
(4,645 Views)
I just got a call from National Instrument's costumer serivce, and they told me that the library "RS232.h" isn't supported in Real Time mode !
Such an inconvenient !
Honestly, I'm not very convince, but they said they'll get back to me with a solution ..
I'll keep u guys updated
Message 8 of 10
(4,637 Views)
Accepted by topic author 0033
Problem Resolved !
I had to install the RT Serial Module !
Cheers
Message Edited by 0033 on 06-26-2009 04:34 AM
Message 9 of 10
(4,623 Views)
Hi.
Very thanks for your feedback here. It should be helpfull for others.
Have a nice day and a great weekend.
Regards.
Romain D.
Message 10 of 10
(4,614 Views)
