1073807339 error with a Hameg hm8118
Dear Dennis
I have written to the support guys and the have replied , found out the problem and solution
the drivers from  NI had a "Line Feed" at the end of each command , but as per the tech support they told it was a Carriage return or End of Line.
I removed the termination character before as it was not working .Hece there was communication some times,but now after using  CR it works as smooth as butter .. :).
Hope this will be helpful for other users.
Thank you 🙂
Message 11 of 12
(763 Views)
Dear Bharadwaz,
I can't find the place in VI from Hameg where I should change the line feed constant to carriage costant. Can you give me some more detailed instructions?
I have the same problem with communication with the bridge...
Thank you in advance.
Cezary
Message 12 of 12
(657 Views)
