I am error code 10737736587 in a vi  while running a sysytem exe.
I am try to open the com port and via the exe an dtrying to pass teh command through the exe.
The com port opening is happening correctly but giving the error message while passing the command.
The labview used is 2012
(2,269 Views)
Please recheck the error code. The one you provided is not valid. Did you attempt to determine the error yourself by using Help>Explain Error n LabVIEW?
(2,260 Views)
