100 hz data skip labview
I am using 25 pressure transmitters along the pipe. I have taken 100 Hz as sampling frequency. But when i run the software, the data skips at 55 seconds intervals. Can you please tell me what is the reason.
(2,962 Views)
Hi
Could you give some more info? What do you mean by "the data skips"? What kind of hardware are you using to read the data? How is it connected to the pressure transmitters? Can you post the VI you are using?
Best Regards
David
NISW
(2,957 Views)
I am using Labview 8.0 software. The pressure transmitters along the pipe through which air is flowing.When the software is run, It stops for 1 second and then starts taking data. This happens at each interval of 55 seconds.
(2,942 Views)
Do you run your program with continuous run button? The run button with 2 arrows
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,938 Views)
