10 bit integer
Hi all,
I have a problem with LabView. I have a 10 Bit Integer value.  The Datarange  is from  -512 to 511. How can I make that LV build the two's complement of this 10 Bit Integer value, because I only can declare a 16 Bit Integer value. I hope that somebody can help me.
Thank You!
Greetings from Germany
Juan
(4,007 Views)
I am far from being an expert in bit computing, but I think the way you should follow is to try to get an array of 10 bit, then add 6 bit at "the appropriate" place in the array so that they don't change your value.
I hope this idea will help you to find a suitable solution, good luck 😉
Epictetus
Antoine Chalons
(3,995 Views)
You don't really need to do anything special other than perhaps providing data coercion on your numeric controls to limit the values to [-512, 511].  To build the two's complement you can just use the following:
Message Edited by smercurio_fc on 02-21-2006 03:00 PM
(3,975 Views)
Thank you!
I try tomorrow at work and I will tell you the result!
Best regards!
(3,957 Views)
