1-wire Labview drivers
hi VADave,
Can i use it using labview 8.6?
it seems its looking for FPGA I/0 stuffs.
Message 11 of 58
(6,535 Views)
You will have to recompile everything for labVIEW 8.6.  You will have to change the FPGA target to match your FPGA target.  Once that is done everything should work.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 12 of 58
(6,510 Views)
I think i may need some expertise on this. Im not familiar FPGA.
thanks
Message 13 of 58
(6,411 Views)
I have developed code to operate the following 1-wire devices
DS2406
DS2450
DS2413
DS2408
DS2438
I got started with the help of code that I found on the NI site for the temperature devices
DS 18B20
DS 18S20
I have also developed code to operate the 1-wire AAG TAI-8540 humidity device – which use a DS2438
I am currently trying to develop code for the 1-wire AAG TAI 8570 pressure sensor device – which uses 2 x DS2406 – although I am not sure exactly how. Has anyone had any success with this one?
Message 14 of 58
(6,148 Views)
I would like very much having an example with DS2438.
I tried with :
http://decibel.ni.com/content/docs/DOC-1092
modified for the 2438, but I do not get the bytes of page 0 as the DS2438 should return after a command BEh00h.
Yet it communicates, it returns its identifier properly.
Message 15 of 58
(6,023 Views)
Here are the VIs are used for a DS2438. I used this for two different 1-wire Humidity sensors.
Message 16 of 58
(6,005 Views)
Hi NeilJohn,  thank you for the answer.
Regrettably, the sub VI Read DS2438 NJB.vi that contains probably the information which I miss is not included in your
1-wire DS2438 Controller via DS9490 USBBridge new.vi
Stephen.
Message 17 of 58
(5,987 Views)
Sorry about that I wrongly assumed the VIs used by the main VI would be sent as well. Here are the VIs that I think you'll need to run the VI I sent. It looks like I can only send three at a time.
Message 18 of 58
(5,979 Views)
Message 19 of 58
(5,976 Views)
And the final three VI - I think.
Message 20 of 58
(5,975 Views)
