1 Long SCPI CMD Single Write vs 1 Long CMD in Chunks vs Spliting CMD to Multi-Writes to VISA
Hi All,
I am trying to program the LIST/Sequence mode on an ELOAD. This load can take up to 10,000 steps in a list and the SCPI command format goes something like this:
PROG:STEP<n>:LEVel
where n is the step number. If I have say...100 steps, then I will need to issue this command 100 times; 1000 steps, 1000 commands, and so on. Some of you might already see where I am going with this based on my topic...
My default go to solution would just be creating the commands in a array and feed it to an auto indexing for loop with a VISA Write inside. However, the wise-guy part of my brain is thinking I can somehow send this thing is one big chunk by using a semicolon ";" to build up all the commands into one giant string.
The immediate redflag with the giant string method is I am thinking somewhere along the way as my list gets to a certain size, I am going to get some I/O buffer errors since the string is going to be huge. So I thought of using something like this to send it in chunks (credit to whomever wrote this original driver, this is from the Lecroy MAUI oscopes):
So in the end I came up with 3 methods of doing this:
a. Send the command n times based on size of list
b. 1 giant SCPI string for n commands
c. 1 giant SCPI string split up in packet chunks to write
I am leaning towards "a" or "c" as I think "b" will run in to eventual buffer issues. However, I am not sure if "c" will even work...I am not really understanding how the IO buffer works. Even if I send it in packet chunks, wouldn't it eventually still overrun the buffer since I am not sending a terminating message until the whole SCPI string is sent?
Mike
(2,421 Views)
Accepted by topic author Mikejj
Combining commands is often a hit-or-miss, depending on the commands and the instrument.  So I would lean towards A (all steps sent individually).  It is also a lot simpler for anybody in the future (including yourself) to have to debug this code.
GCentral
(2,398 Views)
Computers are VERY good at doing repetitive tasks over and over without getting bored.  I would take advantage of this by going with your original plan.  And, as mentioned, it's a lot easier to debug.  I will usually choose readability over performance unless performance is critical (e.g., I have to get this all done in one RT time slice) or the trade-off is unacceptable (e.g., making it easy to modify and debug makes it take 5 minutes to complete instead of 5 seconds).
Bill
CLD
(Mid-Level minion.)
(2,373 Views)
