1/0 Signal Generator
Does somebody know if there is a 1/0 signal generator in Labview 5.1 where I can specify the length of the durtion of 1(true) respectively 0(false)?
(2,699 Views)
if I understand you right you can use "Pulse pattern.vi" or "square wave.vi" from "functions->analyze->signal processing->signal generation" palette. Set the value of amplitude to 1 and you will get what you want.
Good luck.
Oleg Chutko.
(2,699 Views)
