LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
retreiving coordinates from image
Hi everyone,
I am using a template to build an automated needle biopsy robotic system like this.....
The idea behind it is that I will place an MRI image like this ........
Under the robot and then use labview to find the location of "tumor" and make the robot hit the spot with the needle. I am in way over my head so I am asking for what would be the best approach for this project. Is it possible for to get coordinates on a picture through Labview? Thanks for the help!
(6,641 Views)
Hi Dojo,
What exactly do you mean the coordinates of an image? In what format would these coordinates be stored?
Cheers,
Ashish Patel
Applications Engineering
(6,611 Views)
Ultimately I would like the user of the program to be able to pick any spot on the image and for the robot to go to this position. Thanks for the help!
(6,596 Views)
Dojo,
The best way to do this is to determine a start posiiton on the image and then use the encoder to determine where the robot is.
FLash
(6,588 Views)
