LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
problem of number of sample with DAQ assistant
hello,
I'm using DAQ assistant in a while loop to control a rotative system. so, this DAQ is used to generate a signal but I do not have the possibility to control the number of sample labview : in fact, labview create only one sample for 10ms, and I wish it create minimum one sample per ms.
If you have any idea, help me
Regards
Arielle
(6,223 Views)
Can you explain more the kind of control do you want to do (type of Input/output, sample rate,...)?
It will be easier to help you if you post your Vi. Can you post the VI that gives you troubles?
Yann C.
France
(6,212 Views)
I send you the VI have created.
I use two type of signal : with one I generate a signal, with the second a acquire a signal.
In fact, I've found some help to make my loop running faster. and now I have another problem that is that my curves don't go at the same speed. the probleme could be the way I have more iteration. I send you my VI, it could help you
 thanks for helping
(6,210 Views)
