LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
multiple selection with control key in ring, enum, or radio buttons on Speedy-33 ?
Hi all,
I want to create a list of entries via ring, enum, or radio buttons. I just want the user to be able to select more than one entry from the list.. This is normally doable with windows applications by using control key. However, how could I do the same thing or let the user choose more than one entry from the list? Any idea is greatly appreciated..
Thanks so much!
(8,612 Views)
I haven't tried, but some of the official motor and move blocks allow the user to do this.  Can you open the config.vi for any of them?
(8,608 Views)
Hi Casiopea -
To answer your question, I'm not sure I've ever actually seen a ring, enum, or radio button control exhibit the "CTRL+click" behavior you're describing.  (In fact, I think all of those user interface elements are designed specifically so that only one value can be selected at any one time.)
However, I have seen plenty of list boxes allow multiple selection, and LabVIEW's list boxes can do the same.  A group of checkboxes can also end up looking like radio buttons if you group them with some "decoration" and would allow you to select multiple options (because you can check/uncheck each box independently).
I'm not quite sure, though, how your question relates to LEGO specifically.  Did you accidentally post this question to the wrong discussion forum?
To address Eagles Coach's statements, the official Move block uses checkboxes in the "Port" section of the configuration pane in the MINDSTORMS software, not radio buttons.  The Motor block uses mostly radio buttons, and I didn't see any sections that allow multiple selections.
James Blair
NI R&D
(8,605 Views)
ahh silly me.. I am posting this question under the appropriate forum...
Thanks so much..
(8,596 Views)
