LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Terminal error
Hi!
I tried to compile my first NXT program with Labview (the microphone sample program) but i get an error: "An error occured while trying to load the nxt terminal"
I get this error when trying to load the nxt terminal. I have the Mac Version of Labview 8.5
thx
Johannes
(8,686 Views)
BTW: I'm usin Mac os X 10.5
(8,685 Views)
I'm using mac 10.4.11 and 10.3.9 (multiple computers), with Labview 8.5 Student Edition, and I'm getting basically the same error.
An error occurred trying to load the NXT terminal
It works fine on a Windows XP laptop, which has a trial version of Labview that came with the 2009 FTC KOP, and I have successfully transferred programs to the NXT using it. However, I would greatly appreciate being able to transfer programs with my G4, as advertized. The NXT toolkit I downloaded is from only a month or two ago.
Marshal Horn
(8,372 Views)
At first I had the same problem with Mac OS X 10.5 + LabView 8.5, but then I found out, that you have to install the driver for it to work. ( http://mindstorms.lego.com/support/updates/ ) After installing it everything worked for me.
Best Regards,
Lukas
(8,326 Views)
Thank you, that's exactly what I needed!
However, I had to go somewhere else to find it:
http://community.legoeducation.com/media/p/2581.aspx
Marshal Horn
(8,320 Views)
I am wanting to use my Macbook with OS 10.5.  I have Labview 8.2 installed and the Lego NXT toolkit, but when I launch to NXT terminal it shuts down my entire Labview Application.  I have installed the driver and firmware, but the problem still exists!
(7,888 Views)
