LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Read the HMC5883L from sparkfun with Lego NXT
I want to read the HMC5883L with my lego NXT.
But i cant get it working.
In Arduino it works fine in the attachments you find the code for arduino and my attempent for a labview program.
I use 4.7K ohm pull-up ressistors.
Someone know how to get it working?
(7,393 Views)
Not sure, but it looks like you are using the same address to read and write a register? Did you try using 0x3C as the first byte of the first command and 0x3D as the first byte of the second?
(7,380 Views)
Yes, I tried but i still cant read anything on my labview programma.
I added shift registers for reading measeruments like in my arduino example. (attachements)
But as long i cant read anything they have no use.
(7,250 Views)
