LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Hitech Touch Multiplexor
Hi all!
I was trying to control the Hitech touch Multiplexor with the LabView For Mindstorms and it seems that the program does not recognise the multiplexor element. I tried a touch sensor with the LV and it is detected perfectly. I also tried the MUX with the LEGO Mindstorms NXT-G program and it works perfect too. So the only possibility is that the LV does not recognise the MUX or something similar.
Has anyone had the same problem? Can I make some other proofs?
Thank you all!
(5,989 Views)
Please check the following palette for the Touch Mux VI.
NXT Robotics: NXT I/O : Additional Sensors and Motors: HiTechnic Sensors :HT Complete : HT Read
(5,976 Views)
