LabVIEW Web UI Builder and Data Dashboard
example code
The examples provided for this builder are all done in LV2010.
Can some examples in 2009 be provided please?
Message 1 of 8
(9,137 Views)
Is there a particular Web UI Builder example that you'd like to see converted back to LabVIEW 2009?
Message 2 of 8
(9,135 Views)
Lets see.....
Calling LabVIEW Web Services
please
Message 3 of 8
(9,133 Views)
I updated the example to include the code for LV 2009. Let me know if you run into any further issues.
Stephanie A.
Americas Marketing Manager
Message 4 of 8
(9,103 Views)
Thanks Stephanie
All working fine.
Regards
Ray
p.s. Michael.......if mine is the first licence issued for LV Web UI Builder, maybe I should get a T-shirt 🙂
Message 5 of 8
(9,099 Views)
Sorry Stephanie...I jumped the gun
Getting an error 67010, when trying to build the web service
Please see attached image
Regards
Ray
Message 6 of 8
(9,096 Views)
Ray,
I've been testing this out all day to see if I could duplicate the problem. I have not been able to get the same error as you when building the web service from the downloaded project. I tried on 3 different computers with LabVIEW 2009. Did you change anything in the project itself? Also, what version of LabVIEW 2009 are you using. You can see this information in LabVIEW»Help»About LabVIEW... and look at the version number.
The next thing I could suggest is changing the Waveform Graph to an array indicator and see if you can build the web service this way. After changing the graph to an array be sure to add the output to the subVI connector pane. Are you able to build the web service after making this change or do you still get the same error?
Stephanie A.
Message 7 of 8
(9,040 Views)
Just to chime in, I also tried the 2009 files and didn't have any problems building the web service. I used version 9.0 (no patches or service packs installed).
Message 8 of 8
(9,036 Views)
