LabVIEW Web UI Builder and Data Dashboard
Why „visibility“ property (LabVIEW WEB UI Builder) for various controls and indicators cannot be changed programmatically?
Why „visibility“ property (in LabVIEW WEB UI Builder) for various controls and indicators cannot be changed programmatically? When I click on the small dot at the right of “Visibility” property, the pop-up menu (with “Access from Diagram” option) does not show. How can I make control or indicator invisible programmatically?
(6,687 Views)
The Visibility property is an enum type (Visible, Collapsed) and currently we do not support enum types on the diagram.
(6,683 Views)
Another way to make a control visible or invisible: you can also set the "Opacity" (to 0 or 1), and this is available on the diagram now.
(6,681 Views)
