LabVIEW Web UI Builder and Data Dashboard
Force a string indicator to scroll to the bottom
In LV Web UI Builder is there a way to force or programmatically scroll a string indicator to the bottom?
I am building a virtual hyperterminal and I am writting a very large amount of data into a string control.  I have the vertical scroll bars turned on, but by default it just shows the information at the top.  I want to include all of the data so that the user can scroll back to see the history, but it would be nice if by default the scroll bar would stay at the bottom.
(7,707 Views)
I am pretty sure there is no way to do this in Web UI Builder. I can look into this and post here soon.
Vivek Nath
Machine Vision
(7,695 Views)
I just wanted to confirm there is no way currently to force a string indicator to scroll to the bottom. I will note this down as a product suggestion for the Web UI Builder team.
Vivek Nath
Machine Vision
(7,676 Views)
Creates a Scroll Position property node
Set a value big value for it. (if scroll position is set to a value bigger than your data, it goes to the end)
regards
(7,412 Views)
It worked. Thanks!
(7,370 Views)
