LabVIEW Web Development Discussions
Starting Web Service Error -67501
If you run into this error while starting your web service, first take a look here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g12vSAA&l=en-US#:~:text=This%20error%....
If that solution does not work, or does not apply to your situation, then it could be that LV is offended by one or more terminal connections on a VI connector pane.  I've found that this can occur if you rename the controls or indicators that are already connected to terminals.  Try un-connecting and then re-connecting the terminals.
This is with LV2019SP1.  Not sure if it applies to other versions.
(2,153 Views)
Also try removing whitespaces and certainly special characters from the names of controls connected to terminals.  LV seems quite finicky here.
(2,145 Views)
