This function works on Case structures with an enum wired to the case selector. Rather than sorting by the cases by the numerical value of the enum, this function will sort alphabetically (A-Z) by the enum string.
jrayeske: If you please, go to this template and use it as the starting point for your work. The template document will guide you through the upload process. This will make it easier for people to know what your extension does and which versions it supports, etc.
