This right click plugin, allows you to right click on any splitter, and open a panel to view and edit (all VI server editable properties) from a nice simple user interface, instead having to traverse in and out of splitter and pane property settings that are slow to view and edit. In this you can set the names of aoll your splitters and panes, and set the minimum widths and scroll bar settings. All of this is editable and can be changed on the fly from the popup panel and closed anytime. Any edits are immediately applied to the VI through VI server and reflected in the table to show the properties.
