Author: Andrei Zagorodni (Novator Solutions AB)
Inserts an In-Place Elements structure in any wire using menu Insert IPE Structure:
Before:
Select any wire in BD
The plugin was created using plugin LabVIEW Class And Cluster Wire Insert IPE.llb (by AristosQueue) as prototype.
I uploaded new version of the plugin. It recognizes Map data type.
The plugin works with older LabVIEW versions (that have no Maps) as usual.
New version 0.1.1.0 is uploaded.
Previous version did not recognize brunched wires and inserted IPE at wire source.
