LabVIEW Project Providers
Execution trace toolkit on Providers
Does anybody know how to trace execution of the ETT for a provider.
Specifically I am looking at the SCC instance.
My own Mercurail implementation is causing 'Exception: Access violation (0xC0000005) at EIP=0x00000200''
I'd like to track this with the Execution Trace toolkit. However the app-instance for this (mxLV??) is not available for the ETT.
My LabVIEW Ideas
Message 1 of 13
(9,645 Views)
Good question Ton.  I do not know if this is possible or not, but I will follow up with R&D and let you know what I find out.
David
Message 2 of 13
(9,589 Views)
Sorry for the delay, the holiday weekend made it difficult to get the information I needed right away.
I learned that it is possible to Trace the provider context with the addition of an INI token for DETT.  However I want to make sure to put the warning out that the LabVIEW Project Provider context triggers A LOT of events and it may not be completely helpful.  In fact you may experience memory problems if the trace goes on for long periods of time.  The below INI token should be used carefully and at your own risk, just as the Project Provider framework is.  Please also don't share this information outside of this private forum.
INI Location: "<National Instruments>\MAX\Assistants\Trace Toolkit\TraceTool.ini"
INI Category:  [GlobalSettings]
Token:  PrivateContexts=True
Once this token is in place, you should restart DETT, create a new trace, click refresh and choose the App Instance "NI.LV.MxLvProvider"
On a related note, I have learned from the DETT developers that there will be some significant changes going into DETT 2013.  Because of this they are planning an early beta for the product to get customer feedback.  If anyone is interested, please send me a private message with your email address and I will pass your information on to the team who is working on this.
Let me know if you have success with this.
Message 3 of 13
(9,589 Views)
Hey All,
Just as a followup to this, I learned that the DETT 2013 Beta has recently opened.  If you haven't gotten an invite already and are interested in joining, you can go to the Beta Program resource center (http://www.ni.com/beta) to sign up.
Enjoy!
Message 4 of 13
(9,589 Views)
It appears the directory above for the "PrivateContexts=True" no longer exists for the 2013 Beta -- would you report back if we're still able to trace the Provider context, and if so, how to enable it?
I've done some poking around in obvious locations and using Process Explorer, but to no avail so far...
Message 5 of 13
(9,589 Views)
Aha!
C:\Users\<your-user-name>\AppData\Local\National Instruments\Desktop Execution Trace Toolkit\DETT.ini
And now the key is in the [GlobalSetting] section (notice the lack of an 's' at the end)
Message 6 of 13
(9,589 Views)
Would this mean that all new NI products get proper (userified) INI files?
Ton
My LabVIEW Ideas
Message 7 of 13
(9,589 Views)
The new key for DETT 2013 Beta is
[Preference]
ShowPrivateContext="True"
Message 8 of 13
(9,589 Views)
[Preference]
This setting appeared to not have any effect, even when set to TRUE -- it appears that "PrivateContexts=True" from the [GlobalSetting] remains the key that shows private contexts.
Message 9 of 13
(9,589 Views)
Obviously we can't make promises on any future plans, but this is the first product I've heard to make this change.  As always the proper channel is the idea exchange for this type of request.  Sorry, I wish I knew/could say more.
Message 10 of 13
(9,589 Views)
