LabVIEW MathScript RT Module
"figure" cannot pop out in the exe mode
Hi, there, I plot sin(x) well in the vi, using the commands in Mathscript RT as follows: x=1:100; y=sin(x); figure; plot(x,y); However, when the exe file is generated, the figure does not appear any more. Does anyone know how to solve the problem?
(4,138 Views)
Perhaps I didnot describe the problem properly.
I mean, in the Mathscript node, the command 'figure' should work normally, however, when the .exe file is generated, no figure can appear anymore.
I wonder what the '.exe' engine did to the mathscript node.
Any discussion is welcome.
(4,073 Views)
Or, is there any other method to monitor the parameters in the Mathscript Node in time?
For example,
for i = 1:100
pause(1);
end
How to display the "i" in time?
(4,064 Views)
