LabVIEW MathScript RT Module
mathscript variable doubt-help me
Dear Experts and friends,
I reading a serial port one by one character at a time...(i specified in " bytes to read in serial port read node)
The receiving data are sent in a fixed format..and so i need to extract  the data from these format..by using a math script node...and i need to plot it on the xychart...
my problem is with initializing a variable by only once..............and the variable should not re-initialized again and again since program keeps on reading the serial port data....
I need to intialize a these 2 variable  given below only once,while i am start executing.but not again and again..........(meaning that when i start executing for the first time these 2 variable should be intialized,...but when i doing for the 2nd time it should not be initialized again--since i am reading it using while loop.........and these parameters are my reference parameters to find out the data......
ubIndex = 0
bHeader = 0
here is math script code which i have used.......
ubIndex = 0
bHeader = 0
ubTemp=input    //input is the variable i used as input to the mathscript node in char string format
 if bHeader ==0
                 if ubTemp == 89
                        ubIndex= 0
                        bHeader = 1
                   end
else
              ubIndex= ubIndex +1
              ubReceivedata(ubIndex) = ubTemp
               if  ubIndex == 3
                       ubIndex = 0
                       bHeader = 0
                 end
end
 ubChecksum = ubRecieveData(1) + ubRecieveData(2) + ubRecieveData(3)
if   ubChecksum == 0
               if ubRecieveData(1) == 76
                        duLen1 = ubRecieveData(2)
                             elseif   ubRecieveData(1) == 69
                                    duLen2 = ubRecieveData(2)
                             elseif   ubRecieveData(1) == 78
                                       duLen3 = ubRecieveData(2)
                               elseif ubRecieveData(1) == 71
                                            duLen4 = ubRecieveData(2)
                                            duLength = duLen1 * 16777216 + duLen2 * 65536 + uwLen3 * 256 +  ubLen4
                              elseif   ubRecieveData(1) == 80
                                           uwTemp1 = ubRecieveData(2);
                               elseif  ubRecieveData(1) == 66
                                            ubTemp2 = ubRecieveData(2);
                                            uwpackageSpeed = uwTemp1 * 256 + ubTemp2;
                                 elseif  ubRecieveData(1) == 68
                                 else  ubRecieveData(1) == 65
                                         uwDrumSpeed = uwTemp1 * 256 + ubTemp2;
                   end
end
//output variables are duLength ,uwpackagespeed,uwdrumspeed
bHeader and  bIndex should not be re-intialized again...
please see the vi file i attached for better understanding of my problem...........(vjnewsamp.vi)
Kindly suggest some solutions to overcome this problem ..........
regards
rajasekar
(7,254 Views)
One way to accomplish this is to use persistent variables in the MathScript Node.  A persistent variable will retain its value in-between invocations of the node.  Simply declare your variables using the persistent keyword.
persistent ubIndex bHeader
Then, you can pass in an initialize boolean that corresponds to the first iteration of the loop.  In your code, you can initialize the variables the first time using
if (init)
   ubIndex = 0;
   bHeader = 0;
end
The simplest way to pass in the initialize boolean is to wire the Equal To 0? primitive to the loop iteration terminal.  Then wire its output to a boolean input variable on the MathScript Node.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(7,245 Views)
