LabVIEW MathScript RT Module
'find' command
mathscript doesn't give any output when I use the 'find' command to get the index of an array element. I want to find the rise time of a real time signal. Following is the code;
rise_time1 = max(find(act < 0.1));
rise_time2 = min(find(act > 0.9));
rise_time = abs(time(rise_time2)-time(rise_time1));
Any suggestions will be highly appreciated.
Many thanks.
(5,669 Views)
Hi Rabiya,
Are you able to confirm that the array you're trying to get the index of is actually being populated.
Are you also able to post more of your code?
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
(5,594 Views)
