LabVIEW MathScript RT Module
compilation problem mathscript
I have made an algorithm on matlab and I'm trying to use it on labview.
I have the following issues:
-sometimes I can't complie and I have the error:
     MathScript Node 'Pin attached':Code could not be generated
    ->details: Could not get error details
    If I edit some random stuff like adding a new empty line labview will accept to compile the node but weird stuff still happen, I can't set breakpoints in       this node and if I run the code it will not enter inside the node, the outputs will be empty and I can't debug line by line inside.
Here is the code, just don't forget to set the path for the mathscript fonctions
Thanks for your help
Corentin
(6,695 Views)
Just for your information. The following two KB talk about the compile error in MathScript.
Causes of Failed to Compile Error with MathScript Node
Detecting Corrupt Instantiation VIs and MathScript Node Failed To Compile Errors in LabVIEW 2009
(6,659 Views)
