LabVIEW MathScript RT Module
calling mathlab function
Hi guys
I got a problem.
I have to call a mathscript function from mathlab.
I can either wrote the function of the code into the mathscript or call the function.
writing the code of function appear to be tough as it contain alot of subfunction== i will not b doing it
calling the the function.. how to do it? do i just need to paste the m file into the mydocument/labviewdata only?
then it will work? do i need the mathlab in pc or just the file only to make sure it run?
What do i need to do ?and what i need ? and how to do?
pls tell me the steps
(9,560 Views)
Hi sean1985,
it is same as matlab.
if suppose
d='sree'
m=bitgen(d);
here u can use m for your apllications
in tat same folder u have to kept this bitgen function
function y=bitgen('passing valus')
u have return 'y' value.
(9,558 Views)
I dunno what u speaking on. can u repeat?
Or, pls answer the following question
hi guys!
i m completely unfamiliar with mathscript in labview system.
i will ask a few question. answering them will definitely clear my doubts
1) In math script node, i can call and used mathlab function (example xplot, yplot)?
2) In order to do this(1), what do i need to do? like m.file into the labviewdata directory(I'm unsure)? pls describe in layman terms
3)Is there any constraint of function in mathscript? implies all the function found in mathlab can all be used in mathscript?
thks
(9,548 Views)
It is advisable for you to navigate the http://ni.com/mathscript and LabVIEW Help before you start using MathScript.
To give a quick answers for your questions
1) You can call and use MATLAB® functions as well as m-script or user-defined functions.
2) You can call the functions or run your scripts either by MathScript Window or MathScript Node.
3) You can find function list that MathScript supports in either ni.com or LabVIEW Help.
MATLAB® is a registered trademark of The MathWorks, Inc.
(9,536 Views)
Hi sean1985,
i tought you know abt mathscript u r going to use functions.
wat ttrr told is correct ucan follow him
u can use mathscript as matlab,but it support only few function,not as much as matlab.
u know how to open matscript window.
in this two are ter
1.mathscript editor---for normal simulations
2.mathscript node-----for VIs
i hope it usefull to U
sreenivasulu.o
(9,531 Views)
