LabVIEW MathScript RT Module
Plot a labview waveformfrom mathscript
I have this MathScript code. It works fine in MATLAB and Math Script...
t = (0:0.0000001:0.01);
f1 = 0.0011312*cos(2*pi*49400*t);
f2 = 0.003936*cos(2*pi*100*t);
H = (f1.*f2);
x = ((2.93464*10^-10)*H);
ms = 1000;
M = ms*(coth(x) - (1./x));
I want to plot a waveform of M vs t in Labview. How do i go about doing this?
(9,182 Views)
Kris,
You have a few options for graphing data in LabVIEW MathScript:
  1. Create a Waveform
    The waveform datatype in LabVIEW is a cluster of three elements.  One is the array of values (in your case M), the next is the dt value or the time between samples (in your case 0.0000001) and finally the t0 value or start time (in your case 0.0).  You can use the "Build Waveform" VI to put the pieces together and wire it to a Waveform Graph indicator.  See the screenshot below for how to implement this.
  2. Use the XY Graph
    You could use the XY Graph by bundling together the t array and the M array.  Again I've demonstrated how to do this in the screenshot below.
  3. Use the plot() command
    If you don't need the plot on your front panel and just want to see the results in a popup window you could simply use the plot(t, M) command.
(9,179 Views)
Oops -- I didn't edit my own post in time.
Here's the sample code I used:
And here are the resultant plots:
Result of plot(t,M):
Hopefully this answers your question.  If not let me know and I'll try to help you out.
Simon H
http://www.ni.com/support/
Message Edited by Simon H on 12-10-2007 05:32 PM
(9,175 Views)
Thanks for the Help. But i am still not able to do it. I think because in your representation you are using 'M' as a sine wave whereas in mine i am using M as a matrix.
In my case i am getting an error where in my wire from M does not connect to the Y in the build waveform. Also which one am i supposed to use for build waveform...analog or digital...i've used both, it doesn't work.
Thank you,
K
(9,164 Views)
Hello Kris,
In both your example and Simon's example, M is a one-dimensional vector.  When you create output variables on the MathScript node, make sure to right-click the output variable and select "Choose Data Type."  In this case, select the 1D array of double.  This should fix the broken wire you are seeing.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(9,150 Views)
