LabVIEW MathScript RT Module
Plot a graph using Data from Matlab and a SubVi
Hi!!
i am developped this code where by entering a specific angle called Thmax  you will get the corresponding voltages at the output of a Dac. 4 voltages precisely.
Now i need to plot a graph whose inputs are this specific angle and a 1D arry element which i called PHASE in my block diagram.
In matlab, the plot looks like this:
 The single point should be highlited in the graph or at list, be seen.
I tried those sub VIs: - Plot Waveform -Polar plot ( since i am dealing with angle). But still, without a success.
 Please help me out...
Message 1 of 13
(11,816 Views)
In MathScript, you can use the functions plot and polar. And in LabVIEW, you can use the Polar Plot Indicator, which draws polar plot in Picture Control.
Message 2 of 13
(11,815 Views)
I tried the Polar Plot Sub Vi but i noticed that i could only create a control , which is a 1 D array of 2 cluster elements.
My inputs are  a 1D array of elements and a single  point...
Message 3 of 13
(11,796 Views)
Yes, the Polar Plot only accepts an array of cluster to specify the magnitude and phase of each data point. I do not know what your 1D array of elements and a single point stand for. However, you should format your data into the format which Polar Plot VI can accept.
Message 4 of 13
(11,780 Views)
My Vi is at the beginning of the post. I tried to change the data but without a success, that the reason why i had to post my work on the forum...
Message 5 of 13
(11,753 Views)
I want to create a script for bode plot and polar plot without using matlab, is it possibl?
Nidhi
Message 6 of 13
(11,748 Views)
I suppose that you want Voltage array to be the magnitude and Phase array to be the phase for polar plot. Then, you can use the Index & Bundle Cluster Array to generate input for Polar Plot. See the attached snapshot for detail.
Message 7 of 13
(11,746 Views)
Yes, you can create polar and bode plot in MathScript. Note that you should install Control Design Toolkit for the bode functions.
Message 8 of 13
(11,743 Views)
Thanks for your reply but i have one input which i m taking from data portal, & i want to plot the bode plot in report directly in one run?
Nidhi
Message 9 of 13
(11,739 Views)
Are you using DIAdem? I guess you want to draw polar and bode plot in DIAdem report, am I right? The DIAdem can draw polar plot. However, I am not sure whether DIAdem can draw bode plot. I need to check.
Message 10 of 13
(11,737 Views)
