LabVIEW MathScript RT Module
Passing additional arguments to fminsearch
I would like to pass some additional arguments to the function fminsearch.  In matlab, this is usually done using an annomous function ie:
X = fminsearch(@(x) myfun(x, y), x0),
where myfun is the function that I’m trying to minimize and y is the additional argument that I want to pass.  What is the best way to do this using mathscript?
Jim
(8,439 Views)
Hello Jim,
Currently we don't have a mechanism for passing multiple parameters to the function used by fminsearch.  One solution that might work for you is to make y a global variable in your calling script as well as in your myfun function.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(8,427 Views)
