LabVIEW MathScript RT Module
Move code between MathScript Node and MathScript Window
It seems like there should be some way to easily move between the MathScript Node, block diagram view and the MathScript Window.
All I can find is saving to a script and reloading in the other view.
Am I missing something?
(7,520 Views)
Hi wildcatherder,
That seems to be the only way that I've been able to see to interface the MathScript Node and the MathScript Window.
Is there a particular reason you're switching back and forth between the two?
Joel I.
(7,507 Views)
Because it's easier to run code in the Window using static values for variables which are commented out for use in the Node.  There are a large number of VIs which have to run to provide those inputs, when testing the Node in-place.
(7,504 Views)
From what I've seen, your current method is the easiest way to do this.
Joel I.
(7,474 Views)
