LabVIEW MathScript RT Module
Mathscript Output for an Image in Labview
Hello
 I have to read an image from a particular path and load it for doing the Radon Transformation. I have the Matlab codes which works out wonderfully in Matlab. Now when i run it in LabVIEW, i need the values for 2 variables( which are 1 D arrays.) . How can i get the output for these values.
Attached is a screenshot.
Nghtcwrlr
(6,762 Views)
You can choose the appropriate data type, such as 1D array, from the short-cut menu of the output.
(6,751 Views)
