LabVIEW MathScript RT Module
MathScript fir1 function vs. LabVIEW FIR VI
Hi, I'd like to convert some Matlab/LabVIEW Mathscript function into LabVIEW block functions, because it's faster.
One of the function I'm not sure is the FIR function: I have a Mathscrip function fir1(n,W), is "FIR windowed coefficients" its LabVIEW equivalent?  If yes, how should I match the parameters (e.g. is W the high or low curoff frequency? is Order n the same as the number of taps)? If no, which LabVIEW function should I use?
Thanks.
(10,109 Views)
The corresponding VI in LabVIEW is FIR Windowed Coefficients VI. For the simple case b = fir1(n, w), you can use the way as the attached snapshot illustrates.
(10,084 Views)
This is great. Thanks!
Somehow I don't quite understand the reason behind some of the LabVIEW settings (e.g. why the sampling frequency needs to be 2 in order to match the MathScript function, why the number of taps is 1 higher than the order in the fir1, and how the scaling works), but it works!
(10,080 Views)
Here are answer to your questions.
1. In most MathScript functions, the Nyquist frequency is supposed to be 1. That is to say, you need to set sampling frequency to 2 in LabVIEW VI.
2. In MathScript, n specifies the order of filter. However, in LabVIEW, taps determines the total number of filter coefficients. That is why you need to increment 1 to match n with tab.
3. By default, fir1 scales the filter coefficient according to its type. You can also direct MathScript not to scale the filter coefficient by specify option to be 'noscale'.
(10,077 Views)
Thank you very much for the explanation! It's very helpful.
Would you be able to help with "translating" another MathScript/Matlab function into LabVIEW VI? I cannot find a suitable block function for "freqz(b)". I tried it using 3 steps: firstly using "FIR filter" function to apply the filter coefficients b into a filter, then apply a constant signal and get its filtered signal using this filter, and thirdly use the original constant signal and the filtered signal in "Frequency Response Function (Mag-Phase)" to get its frequency response. However it doesn't work. Could you give me some suggestions? Thanks in advance.
PJI
(10,074 Views)
freqz is a little complicated. I do not know any counterpart in LabVIEW. Maybe, you can find it in Digital Filter Design toolkit.
I think the possible way to do is to calculate the frequency response of a filter from its mathematical definition.
(10,069 Views)
Thanks for the reply and advice.
I guess I will just leave this part in a small MathScript window in my VI.
(10,067 Views)
