LabVIEW MathScript RT Module
Incompatibilities between 8.5 & 8.5.1?
I have some very basic mathscript code that I developed with LabView 8.5. A colleague of mine took this code and saved it in LabView 8.5.1. Now when I try to open the VI on 8.5 everything loads ok, except the MathScript portion.
I get following error message: "MathScript Node 'MathScript Node': VI failed to compile."
The only way to get the code running again is to delete the MathScript node, create a new one and retype all code. Is there no easier way out?
(7,797 Views)
Could you attach you script? Thanks!
(7,793 Views)
According to the 8.5.1 bug fixes, Mathscript received a lot of attention, so maybe something broke.
Instead of "retyping" all the code, it is probably sufficient to cut and paste all the code at once. 😉
(7,788 Views)
It's the same code as I've posted in this previous message.
Really, nothing fancy
(7,782 Views)
sure, but you still need to manually create all in- & outputs.
(7,781 Views)
