LabVIEW MathScript RT Module
How to return struct from a MathScript function?
Could someone guide me how to return struct from MathScript node if I have something like this in it:
[stat.mymax, stat.mymin] = mymaxmin(1, 2)
The script looks like this:
function [mymax, mymin] = mymaxmin(a,b)
%max min
mymax = max(a,b);
mymin = min(a,b);
end
And the code:
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(7,434 Views)
It seems that output will not be automatically assigned because mymaxmin function is included in run time with addpath function...
Michał Bieńkowski
CLA, CTA, CPI
(7,414 Views)
Accepted by topic author bienieck
To close the subject:
To be able to automatically assign output structure in a custom function I needed to set MathSript Search Paths: Tools > Options >MathScript > Search Paths.
From my understanding, it will never work with addpath() and in such case, I need to manually assign output data types (and I believe struct will not be an option).
Case closed.
Michał Bieńkowski
CLA, CTA, CPI
(7,403 Views)
