LabVIEW MathScript RT Module
How can I load a file
I am a new user in LabVIEW Mathscipt and have a question about how to load a read-only data storage file from any arbitrary directory in my hard driver. Can I use load command? or other command I can use? Thanks
(6,529 Views)
You can use the load function. Please specify full file path if your file is not in MathScript searching path.
(6,474 Views)
