LabVIEW Embedded
run ARM when turned on
Hi all,
When I upload a VI in to my lm3S8962 board, it run as long as  it is connected to the PC. If I disconnect the PC, turn off the board the turn it on without connecting to the PC it doesn't run. Is there a way to let the VI run automatically by turning on the board like with C-RIO?
Thanks, Neil
(7,028 Views)
Accepted by topic author neil84
Hi Neil,
You will need to disable debugging for this to work.  Just untick the box in the build specification that reads "Enable Debugging" and rebuild/run.
(7,025 Views)
Thanks Gmg
(7,020 Views)
I was trying Vi  examples from "find examples". the las example I tried is"game.lvproj" that doesn't not run in debug mode. After that 'm not able to buid any Vi even a simple blinking VI. I recieve this error message:
Build Failed Build target 'LabVIEW' linking... Program Size: Code=18512 RO-data=576 RW-data=1144 ZI-data=37968 ".\Obj\LabVIEW.axf" - 0 Error(s), 0 Warning(s).
I restardet labview and the PC and I'm not able to build the VI.
How to resolve this?
Thanks.
(6,981 Views)
I unistalled uVision and Labview ARM, cleaned the registry, restrted tje PC, and reinstalled them again. And now it is completely random, one time it build and an other time it gives me the error above
(6,975 Views)
