LabVIEW Embedded
labview arm spi protocol
I`m trying to read out an Interpolation-Hardware using the SPI-Port of the lm3s8962-Eval-Board.
Does anybody know the type of SPI-protocol used in the Labview-ARM-Toolkit.
For my Slave-Hardware i need the Freescale-Protocol(16Bit)....
At the moment i can sent data but i dont recieve anything.
I also need to know if its possible to change the settings of the SPI-Configuration(maybe to change the time between data-packeges).
I`m using: Labview2011+Labview Embedded for ARM-Module+lm3s8962-Eval-Board(not the usb-type)+GEMAC IP2000 (Ipo-IC).
Thank you for help!
(6,447 Views)
I think as SPI doesn´t specify a particular protocol so do the LabVIEW ARM SPI functions.
You are free to change all the parameters the Interface offers, so there is no special protocol used with the
LabVIEW ARM Module. Please check out the SPI-documentation of your slave with respect to timing and clock configuration.
I´m sorry, but thats all I can say.
Marco Brauner NIG
(6,438 Views)
