LabVIEW Embedded
delete host program from real time controller
using NI9642 sbrio the host program in the real time sbrio as a startup program now when i am using fttp: for deleting previous host program i can't delete it especially when i delete the host version from the project i am looking for a way to delete the file and working with new real time application program which i use it now.
(6,696 Views)
Accepted by topic author AlaaShaw
Hi AlaaShaw,
Have you tried undeploying the executable from the target and then deploying the new application?
(6,686 Views)
Thank you I have been found a way to delete the files from the target and its work perfectly, I am using the CMD command window the using the ftp address to go through to delete this files.
(6,680 Views)
