LabVIEW Embedded
continuous serial connection with LM3S8962
Hi all,
I'd like to make a serial connection  between an lm3s8962 board and the PC. That means that as long as the while loop is running, the board is recieving some datas and transmittin some others
I did'nt found the way to change  the VI on "Labview Examples" to do that.
thanks, Neil
(7,420 Views)
To control the LED I would draw something like this for the target part:
And this for PC:
Notice the VISA VIs for PC and Serial Compatibility ones for embedded target.
I am sure you can finish the PC part.
(7,418 Views)
Hi Nic,
Protocols are my Achille's hell  :smileysad:
I tried your snippets, but there is no communication between le Board and the PC
(7,358 Views)
Actually in this case it’s not about protocols but … EIO.
Here it is the project (for your convenience I changed the display part too).
(7,342 Views)
Hi Nic,
When testing the Project, the only possible COM possible to select is COM3.
In "Setting Panel" COM3 is not related to the ARM Board.
I think that the board is not recognized by the PC.
When I installed the ARM module,  Iexecuted "Typical install"where "Laminary micro sriver" is deselected. is this the reason to the problem?
I'm not able to reinstall the driver:
(7,306 Views)
I don't understand how you handled the annoying "New Hardware Found" dialog until now.
Or, the board is not detected...
The driver should be in the board's CD too.
(7,284 Views)
