LabVIEW Embedded
arm directory listing
I'm working in a lm3s8962 evaluation board trying to datalog some data and i came up with a problem when I want to retrive that data. The "list directory" doesn't work, I'm attaching the vi file in witch I tried to get the list directoy and after that read a text file written with my pc.
thx
(7,322 Views)
Update!!!
Now I'm using a new vi to work with files (attached).
It writes a file, it reads it then i get the size of the file in bytes and finaly I try to get a list of names of the files in the sd card, but in this last step I get a "PDAFileListDirectory() Error code: 1" error
(7,309 Views)
Accepted by topic author Assambler
OK, Thx to NI support spain the problem was solved.
the solution was to work in a directory, not in the root of the sd card
(7,160 Views)
