LabVIEW Embedded
analog inputs
I am using EIO nodes to read the 4 AI channels on the LM3S8962.  The ADC on the chip is 10-bit converter, correct?  The outputs are U32s.  Are these numbers the actual voltage values on the AI pins, or do these need to be scaled?
(6,880 Views)
12 Analog-to-Digital Converter (ADC)
 An analog-to-digital converter (ADC) is a peripheral that converts a continuous analog voltage to a discrete digital number. The Stellaris® ADC module features 10-bit conversion resolution and supports four input channels, plus an internal temperature sensor.
 so yes 10 bit, and the output is the voltage.
0 = 0 volt
1024 (10 bit) = 3.3 V
Wouter.
"LabVIEW for ARM guru and bug destroyer"
(6,879 Views)
You can also change between returning a scaler (double 0-3.3) or a raw value (U32 0-1024) by right clicking the EIO node and selecting properties.
(6,865 Views)
Thanks for the input
(6,853 Views)
