This widget could not be displayed.
LabVIEW Embedded
Warning: Incompatible arguments: SSI Config Set Exp Clk
I want to simulate LM3s8962 board as SPI slave device and developed below vi. Howerever while deploying it in to board I got follwoing warnings and not able to debug during running code in the board.
[2:21:15 PM] Status: Warning
The following C code generation warning(s) occurred:
Warning: Incompatible arguments. You cannot enable
C function calls on a VI on which you enable
debugging. Disabling C function calls. Source: SSI
Enable
Config Set Exp Clk
debugging. Disabling C function calls. Source: SSI Data
Get
3 warnings and 0 errors occurred.
[2:22:36 PM] Status: Build Succeeded.
(6,722 Views)
Following is the path of VIs:
Functions >> ARM >> EK LM3S8962 >> StellarisWare >> SSI >> SSI Config Set Exp Clk VI
Enable
Config Set Exp Clk
Get
(6,721 Views)
