LabVIEW Embedded
Using LabView instead of IAR Workbench
is there a  way to program the MSP430 with the FET430UIF tool via labview without opening IAR IDE or even having to install it  (just using the output file generated by it : msp430.txt, or ....hex , and the msp430_dlls(drivers) ??
thanks for any help
(6,873 Views)
There has already been a post to this topic:
https://forums.ni.com/t5/LabVIEW-Embedded/Can-Labview-be-used-for-programming-of-Texas-Instruments-M...
You already pointed to this DevZone entry: http://zone.ni.com/devzone/cda/tut/p/id/11977
-> The C Code Generation Tool is explained there. This means you can convert algorithms (not front panels) to regular c code. Then you can run this c code through e.g. the IAR Workbench just as any other c code and compile and deploy it.
So for the MSP430 you cannot use the LabVIEW microprocessor SDK, but you could use the LabVIEW C Code Generator .
Let me know if that helps!
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(6,806 Views)
