LabVIEW Embedded
Strange execution of timed loop with labview ARM
Hi Nic,
Neil
Do you have an English LabVIEW version?
Also, what operating system do you have?
I am asking this because there is already a known issue for Japanese (
Installation of the LabVIEW ARM Module fails if %TEMP% contains Japanese characters)
I suggest you try all examples provided in LabVIEW 2009\examples\lvemb\ARM\LM3S8962 and tell us or NI support if they are working or not.
After that we could go further and see if the algorithm from CRIO is deployable to ARM
I use English LV
The las time I posted I was using Vista Home premium x32
Now my OS is Windows 7 Professional RC w64 french
I have the same error on Debug mode:
[15:52:38] Status: Error
Error generating debug information.Error in expression
Detail: [UVSC_DBG_CALC_EXPRESSION, MSG: 0x200A, STATUS: 0xD]
 (13)
Message 11 of 14
(3,523 Views)
I cannot see 7 here http://joule.ni.com/nidu/cds/view/p/id/1049/lang/en
However, it seems we are drawing near, and NI France support team might be interested.
Bon chance
Message 12 of 14
(3,510 Views)
Hi Nic,
I did'nt found the way to solve this problem, so I shoud execute my codes without debugging.
Now about the frequency of the loop, do you know if there is a way to run it about 20kHz?
thanks
Message 13 of 14
(3,448 Views)
Neil
The good news is you can easily configure using Timers.
There might not be a bad one if you share with us the algorithm run with 20 KHz frequency.
Not everything is possible.
Message 14 of 14
(3,445 Views)
