LabVIEW Embedded
Serial communication data sorting
Hi all ,
   Recently i m working on a project using labview , overview of project is that i m taking data of three parameters using ''serial port read'' tool but the problem and i want to show this data on different  guages but the problem is that how i sort my data as per different parameters, data is taking out from single serial port is their any solution .... ?
(4,936 Views)
This is not really a LabVIEW Real-Time development question.  You would find a better solution by posting your question on the standard LabVIEW Discussion forums found at http://forums.ni.com/ni/board?board.id=170.  Good luck in finding your answer.
Brian K.
(3,261 Views)
