LabVIEW Embedded
Programmatic setting of IP address on ARM target
Is there a way to programmatically set the IP address (and other network settings) for an ARM processor.  (I'm using the LM3S8962 evaluation board.)
My intention would be to start-up using DHCP and then allow the user to change to a specified static IP address if desired.  I know that this can be set in the LabVIEW project but the end user wouldn't have the LabVIEW ARM module to make these changes.
(6,386 Views)
There is not any solution without C. Here it is a snippet:
Note: the IP changes are made in RAM, next time the board will start again in DHCP.
Hint: form more settings see the definition of LOCALM in uVision.
(6,380 Views)
