LabVIEW Embedded
Pblm with elemental IO Prop Node
Hi everybody,
I tried to use elemental IO Prop Node with the Unix and the Phytec target but I got the same error with this two target :
"An internal software error has occurred. Check you LabVIEW and target software installation. Contact National Instruments technical support at ni.com/support. Error details:
Error 1055 occurred at Property Node in PHYTEC_ScriptPropNode_0.vi->EIOPropertyNodeCommonScripter.vi:3->EIOPropertyNodeCodeGen.vi:2->EIOPropertyNode.xnode:EIOPropertyNode_GenerateCode.vi:1->EIOPropertyNode.xnode:EIOPropertyNode_GenerateCode.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Object reference is invalid
Thanks for your help,
FP
(7,753 Views)
Hi François,
Could you describe what you were doing when the error occurred (dropping the node, opening its properties, etc)?
Michael P
(7,750 Views)
Hi Mickael,
I just drop the property node to set the Gpioline property (I choose the gpio line I want to configure and create a constant to set the line as output).
But by doing that, the "run arrow" remains broken and the internal error happens when I click on the "run arrow".
(7,744 Views)
I have reproduced this issue and filed a corrective action request #104720.
Michael P
(7,712 Views)
Ok, thanks for your help Michael.
Do you know approximatively when the patch going to be released because I need the EIO property node for a project ?
Thanks again,
FP
(7,704 Views)
The issue has not yet been investigated by R&D, but I do not expect this to be resolved via a patch. This issue will most likely be addressed in a future release. Until then, if you need to use I/O on this example target, you can call external C code via the Inline C Node.
Michael P
(7,697 Views)
Ok I will do that, thanks for your help Michael.
Have a great day,
FP
(7,691 Views)
